How Many More Boost W/ 6.0L Heads?
Originally Posted by BoneSS
Like the subject says, how much boost can you run by lowering the compression w/ the 6.0L heads?
I believe and this is dependent on headgasket thickness as well, they'll drop you to 9.5:1 , just cause the compression is lowered doesn't guarantee a better safety margin. You are still running a cast piston and that's your weak link right there, the ringlands can't hold the boost.
i speak from experience unfortunately. saving up for a forged block now.
Is it really worth it to go w/ a new forged 346 or maybe iron block from the beginning and selling the existing engine inorder to make some money off the engine before something bad can happen? I have been hesitant to go that route b/c the car only has 29k on it, but I would hate to run that risk.
