Meth pressure switch/ Cheater cam
Old 10-14-2005, 06:07 PM
shawn_c992001's Avatar
Default Meth pressure switch/ Cheater cam
How can I tune my pressure switch on my STS meth kit, it's dumping meth as soon as I flip the switch to the boost controller/meth injection. Also how does the "Cheater" cam work with a turbo setup?
Old 10-17-2005, 07:19 PM
Anybody?
Old 10-17-2005, 07:57 PM
frcefed98's Avatar
Saw this the other day and forgot to post up
I have the STS meth kit too. On the control box located on the harness behind the kick panel, you'll see a small black "switch"
It has 3 prongs if I remember right so look for those. On the back of the switch you'll see a tiny set screw. You can turn that in or out to adjust when the meth comes on. I'm sure if you turn in the screw you increase when the meth turns on. I haven't messed with it since I just installed mine.
J
Old 10-18-2005, 06:42 PM
ok I'll try it
Quick Reply: Meth pressure switch/ Cheater cam
