Vortech cooler proper drain and fill
Old Oct 18, 2005 | 07:07 PM
cputech's Avatar
Default Vortech cooler proper drain and fill
When my Vortech V9 was installed the installer inadverdently only used water vice a 50/50 mix. I need to drain this prior to winter and get refill with a 50/50 mix.
I am planning to disconnect the very top hose (see picture) add fluid through that hose and just wait for antifreeze to come out of the opening.
I think this would limit any air being trapped into the system. The only other way, would be to get underneath and disconnect my front fasica. But that makes no sense since the cooler does not have a chock valve to drain.
