Incon Car - Smokes Blue When Cold On Decel
Also got another problem. Car stumbles at low rpm ( 1000-1800 ) badly. Above 2krpm it clears right up, but if I lay into the car hard it will still stumble in upper rpms. This just came out of nowhere. Checked the plugs they're fine. Next I plan on swapping in an extra set of coil packs and wires. The fueling is dead on, so I'm thinking it has to be spark.
Help me out guys, am I headed in the right direction with these issues?
I really don't want to have to pull the turbo unless absolutely necessary.
- Dug
weird place for a stumble at those rpms....i might would try looking at the TPS to make sure its tracking smoothly...really just throwing stuff at ya....
ya, the stumble is really odd . . . I'll take a look at the TPS . . .
This was posted last year I think but I dont rember by who.
"For the passenger intercooler, drill a small hole on the front lower section of the bottom tank and drill and tap for a 6mm bolt as a drain hole. Open the hole, put a drain pan under it and start the car. Most of the oil in the hose from the compressor to intercooler will be forced out. I would replace the oil check valve as I know my car and Mike's car both had them stick open while sitting for extended times. The cartridges themselves started coming with restrictors built in at the time of the LS1 kits but LPE adds about a .026 restrictor to each oil inlet of the turbo if memory serves me correct. The only other oil issue i ran into is with the use of the weldon pump. If you are using this scavenge pump, you should also be running a one way check valve (maybe .5 psi crack pressure) between the pump and the oil pan so the oil cannot run back down to the passenger turbo while sitting."
I don’t have the oil drain tanks that sit under the turbos on my kit so the oil will sit in the turbos when I turn off the car. I have the scavenge pump hooked to the fuel pump switch so I just hit the key 3 times every time I turn off the car and that primes the pump and sucks the oil out of the turbos. If I forget to do that it will smoke the next time I start the car for about 5 minutes.
I never had a problem. Now that my car has been sitting for 6 weeks with a blown rear, I notice oil in the pass. side I/C and in the tube too. I start it and warm it up every 2 weeks. Maybe my check valve is stuck?
Soon as I put the new rear in I will see if the problem goes away after a few spirited runs.
As far as the checkvalve at the pan BEFORE the turbos, I've pulled off the lines and didn't get any oil to come out, that should tell me it's working fine, right? 'Cause when we were putting the motor back in that checkvalve got bent to the side some; I wonder if that could be the problem? And even if it was, wouldn't I see oil in the driver's side too?
- Dug
I guess those drain tanks are for collecting the oil from both directions, not just for the oil draining out of the turbo when you shut it off but for the oil draining back from the pump to the turbo. They give it a place to go.
Id put mine back on but they sit so low that they would rip off on a NJ pothole. The roads here are sht.
