Automatic trannied turbo guys...
What tranny (A3 or A4 with a brake or no), rear gears, converter (stall and STR), and tire size are you guys running?
500-600 HP, I am thinking about going with a TH400 which I would need a new converter for so I am just trying to get a game plan together. It makes 501 now, and I am making some changes to it so it will be between five and six hundred HP.
4l60e, vigilante 3800, 2:73s out back for now(im gonna see how they do with the turbo before I go lower) cant really tell you much about it yet though I just put the converter a couple weeks ago and havent driven it only a couple times since it keeps snowing here.
6 Second Club Moderator
Originally Posted by Leo@GMRSPEED
Even a decent built 4l60 should handle 5- 600 and you keep O/D. I myself am going with a Rossler T210, rest pretty much the same as what NA$STY is using.
Leo you going with a Glide or a TH210??? The TH-210 is a TH-400 with a 2.10 first gear...... thats the same Tranny Steve Turley's running.
Either way Rossler will take care of ya and it will take the abuse you put towards it.
Kyle
Suspended Sponsor
Kyle
Kyle
Im going with the 210, liek the 3rd gear to keep some kind of streetability, Rossler is the man I know, plus hes not far at all from our shop. the 210 is his cream of the crop, lol I can pass it up..not cheap though.
Yeah there's no real lose in streetability with a Glide over TH-400....
400's 3rd gear is 1:1
and Glided 2nd gear is the same 1:1
The reason i went with a glide over a 400 was the first gear. easier on a turbo car at the launch and the fall off between 1-2 isnt that bad when you have the HP to do it..... i went with the 1.80 first gear.
Plus if it ever does break a glide is alot cheaper to fix.......
Ill agree with ya the TH210 is the cream of the crop.....
Kyle
Pathological Modifier
Moser 9" with 3.50 gears
Yank Pro Yank Extreme 3400 2.6 STR
Hoosier QTP DOT 27X11.50X15
Rossler 4L80E w/ Brake
Midwest custom lockup converter
3.50 gears
28" tires
If you havn't bought a tranny yet. Get a well built TH400 if you don't need OD. Power is a nasty drug and your going to want more. If you start out with a good tranny you'll save yourself money in the long run.
3.50 gears
28" tires
3.50 gears
28" tires
3.50 gears
28" tires
Amen to that...... why spend the $$ twice.... been there wasted that....
