Eagle H-Beam Rods Good For?
I'd guess around 1000-1100 fwhp...? Usually the bolt gives way before the rod...I'm running eagle 4340 H-beams with L19 bolts and no problems thus far...we'll see how she does at the track though. RPM is probably just as important a factor as flat out power too...
on 4cyl's the eagle 4340 H-beams with 3/8" arp 2000 bolts I have seen them do 700whp and 8500 rpm and there rated for 1000flywheel hp I would think you could do close to double that with them.
IMO, the bolt stretch is more a concern of rpm and weight of the piston/rod/pin....on the power stroke, the rod is being pushed down(little bolt stress)...some side loading due to rod angle though....
