dyno question
dyno question
If running a turbo car on a dynojet (vs. mustang) why not dyno it in 5th gear if it is not loaded properly in 4th? From what I understand the dyno doesn't know what rear end gear you have, it just checks how fast you spin the weight and your RPM's.
Why won't this work (dyno in 5th to load turbo better)?
That is a good idea, providing that the 5th gr can handle the extra power and the tires and dyno can handle the extra MPH. Doing this would better simulate the extra load that the engine would see on the street. If this is an inertia only Dynojet, it simulates a 2500 Lb load on the car with no provision for simulating air resistance as MPH increases. This would prevent normal turbo spool-up and not expose real detonation that shoud be tuned out. ABeasst states, "you'd be skewing the dyno", I think that it needs to be skewed if it does not provide the proper load for tuning purposes. Actually, aren't we un-skewing it?
I have 4.11 gears, SO, if I run in 5th it is like running in 4th with a 3.08 gear in the back.
4.11 rear end gear in 5th final ratio -> ~3.04
3.08 rear end gear in 4th final ratio -> ~3.08
Any thoughts why this will not work to help load up the car properly on a dyno and get the tune more accurate?
You got it, this will better emulate real world engine loads for better mapping of fuel and spark on an inertia dyno. I would rather error on too much load while tuning, you may race someone up a hill.
We are discussing the best tuning proceedures, however, less important, on some combos 5th or even 6th can produce more measured RWHP. A higher trans gear reduces the engine/drivetrain inertia losses due to their lessor rate of acceleration which sometimes offsets the slight loss in a transmission's efficiancy. But if the rear gear and transmission gear combo generates too high of a testing MPH, the additional tires, gears and bearing frictional losses negate the lessor rate of acceleration gains. So peak HP/TQ measurement gear selection vary, often unpredictably.
Originally Posted by kbracing96
Peak numbers won't be as high as you would have more drive train loss, as you are not running 1:1 though the trans in 5th gear causing more friction with gears turning at different speeds..
Originally Posted by engineermike
We found the opposite to be true. Dyno'd my last car in 1st, 2nd, then Drive. The power and torque numbers were progressvely higher. The way it works is the drivetrain weight absorbs less power when it rev's slower in the higher gears.
1, you are loading the turbo more in D and 2, there is less drive train loss being in D as all the gears in the trans a spinning a the same speed.
2. Efficiency of a gearset has little to do with ratio, be it reducing or increasing.
When you use an inertial dyno, a certain amount of power is put into accelerating the crankshaft, damper, converter, transmission gears, driveshaft, and wheels. The slower all of these accelerate, the more power can be put into accelerating the drum. So, with higher gears, the rwhp reading will only go up to a point of diminishing returns.
With my old combo, the numbers were:
1st: 260 rwhp
2nd: 315 rwhp
3rd: 335 rwhp
I'm sure if I had dyno'd it in OD, it would've been somewhere around 340 rwhp.
