Eboost...and Vacum Plumbing...
Old 04-21-2006, 10:49 AM
MECHAM's Avatar
Default Eboost...and Vacum Plumbing...
this is how i have mine setup (Eboost and Vacuum plumbing)
Are these correct?
I always see references that the WG should have a reference to the turbo or manifold..but Eboost documentation shows nothing of the sort.
Attached Thumbnails Eboost...and Vacum Plumbing...-2778043890076734921pfrfsv_ph.jpg   Eboost...and Vacum Plumbing...-vac.jpg
Old 04-21-2006, 10:51 AM
Boostaholic's Avatar
You need to take boost/vac from behind your throttle blade, I get mine from some fittings on the left and right side of the intake manifold right up close to the throttle body
Old 04-21-2006, 10:56 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
whoa that looks different than the eboost diagram that i have....from the solenoid,i have 1 port going to 1 port on the wastegate,another port said go to vent or to boost side only,and the 3rd port has a T from the other port of the wastegate to the turbo.Than the vacuum line off the gauge has a T that goes to the brake booster and the BOV.And the fpr is boost only b4 throttle body.we need jose to get on here!
Old 04-21-2006, 11:15 AM
MECHAM's Avatar
there are 2 settings for the eboost...the one you just described is method #1
Old 04-21-2006, 05:36 PM
ddnspider's Avatar
i thought the other setting was for an internal wastegate?but u dont have 1 of those so?i take it there are just different ways to connect it all then
Old 04-21-2006, 07:22 PM
BLk01SS's Avatar
I think there's two different ways to connect them. With a twin setup I know there is.
Old 04-22-2006, 08:18 PM
Dr.x's Avatar
you are correct I have an external so I set mine up just like you from the eboost diagram and it works fine
Quick Reply: Eboost...and Vacum Plumbing...
