HP guess
HP guess
Ok you guys know more than me....this is my setup that will be completly installed this friday.....let me know what you think i will make at the wheels.....and if i am missing anything simple.
M6 Tranny
Stock motor 60k miles
LS1 STS Turbo kit
Tial BOV
Tial 38mm Wastegate w/ 8.7psi(.6bar) spring
GT-67 Turbo
60LB Mototron Injectors
TRT Custom front mount intercooler (FMIC)
255lph Walbro fuel pump
Boost A Pump
T-bolt clamps
NGK TR6 gapped to (.28) willing to take better ideas
Clutch Masters Clutch
Clutch Masters Lightweight flywheel
Ram Adj. Master Cyl
AEM Wideband A/F Gauge
AutoMeter SportComp Fuel Pressure Gauge
AutoMeter SportComp Boost Gauge
Pillar Pod 3 x 2 1/16
Comp 918 Valve Springs
Chromly Pushrods
Compcams xer dur 224/224 Lift 581/581 lsa 114
Grantilli MAF
!AIR
!EGR
160* thermostat
Tuned by Jeff at CAM
my main worry is my cam...i have not really heard anything useful about this cam....i know it got me a good amount of hp with N/A but will it really help or hirt with FI?
M6 Tranny
LS1 STS Turbo kit
Tial BOV
GT-67 Turbo
Boost A Pump
T-bolt clamps
Ram Adj. Master Cyl
Chromly Pushrods
Grantilli MAF
!AIR
!EGR
160* thermostat
LS1Tech Sponsor
im really hoping you hit 525 or so on the 8 psi. if you hit over 500, im set on getting the same set up!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
LS1Tech Sponsor
sorry to hijack... but at what power should you be looking at using the Boost A Pump then?
__________________
came with the kit i bought.....so i am hooking it up, because why not...if the guy tuning it says unhook it i will
but these responses are great....if i make 525+ i will be a very happy man
