Driving with the T76
Old 06-15-2006, 07:58 PM
WestSide's Avatar
Default Driving with the T76
Got the boost gauge, BOV, and all the other little misc. **** fixed...driving in 3rd gear around 30mph...maybe 20% throttle...the turbo spools pretty loud but the gauge doesn't show me getting into boost. Just want to make sure that it shouldn't be boosting yet. Stock LS1 with a mild cam, T76-gtq...thoughts?
Just worried
Old 06-15-2006, 08:09 PM
2002/Black/SS's Avatar
i still haevnt been in a boosted ls1 one but ive been in many other boosted cars and none of them would of been boosting at 25% throttle in any gear, one of friends car that i fequently drive with a pretty big turbo for the car only gets into boost with a very strong press of the throttle past only 3000 rpm
Old 06-15-2006, 08:16 PM
Got Me SOM's Avatar
what vacuum source are you tapped into. You will be in vacuum until about 3500 then you should be well into boost.
Old 06-15-2006, 09:19 PM
Mr_president's Avatar
shou;nt be boosting but maybe at zero manifold pressure or so!?
Old 06-15-2006, 09:29 PM
93formto98T/A's Avatar
I DD my TT car and I can hear my turbos "spooling" up pretty good just cruising around say no higher than 2500rpm and just 25% throttle. But of course it's not getting past 0psi. LOVE that sound!!
Old 06-15-2006, 10:00 PM
WestSide's Avatar
So the vacuum should idle at 15 or so, when i get it closer to 0, it sort of hangs there and doesn't go up to boost...that's ok? I don't want to get into boost, do I need to quit getting it up to 0 without a tune yet? My car was pretty rich before the swap, high 11s on an LM1. I don't have access to the LM1 anymore...am I going to hurt anything staying out of boost but getting up to 0?
Old 06-15-2006, 10:25 PM
ya stop doing that you could hurt something if you try to step on it to send it to zero mani pressure. 15 is good but could be better mine is like 19 it sounds like there might be a little leak in your lines somewhere (dont take my word for it though) mine used to be a 15 till i got it tuned they found a leak or to.
Old 06-15-2006, 10:28 PM
WestSide's Avatar
I'm not really stepping on it, maybe 15-20% throttle. Just to get moving...no more? Guess it's time to shell out for another wideband.
Old 06-15-2006, 11:10 PM
15 inches of vacuum sounds alittle low to me
Old 06-15-2006, 11:31 PM
Got Me SOM's Avatar
15 is ok. that's what my car runs, it could be cause of his cam.
Old 06-15-2006, 11:39 PM
longrange4u's Avatar
15 is ok.... it will stay out of vacume but out of boost unless you mash it to get it to spool.
Old 06-16-2006, 12:02 AM
Mine runs 15vac as well. Many factors to consider. Should be fine.
Old 06-16-2006, 02:11 AM
Wnts2Go10O's Avatar
jus downshift and nail it... ull be in boost then sounds like youre just a lil ancy thas all
Old 06-16-2006, 06:00 AM
smokinHawk's Avatar
Just worried
under part throttle you will hear the turbo spinning, making a whistling sound, though you may not be boosting yet, thats normal.
it wont go into boost unless you give a good load under the car when you get moving.
if you hammer it from down low in the rpm range, then the boost gauge should go to zero, then build up boost from there.
Old 06-16-2006, 03:05 PM
WestSide's Avatar
Cool guys, thanks for the replies. This is my first turbo car, driven some WRX's and LGT's but nothing feels/sounds like my turbo. I used the brake booster for the boost source...still trying to find a better way to route the lines into the passenger compartment.
Old 06-22-2006, 10:30 PM
Bird-Of-Prey's Avatar
Sounds great. What are the specs on your turbo? Specifically what A/R and what flange T4 or T6?
Old 06-22-2006, 11:31 PM
67Firebird455's Avatar
LS1Tech 20 Year Member
Yeah, at low rpm and that much throttle, you'll hear the turbo spooling for sure, but you definitely won't be in boost... That's a relatively large turbo for the 346, and only 20% throttle isn't gonna boost. I did have a problem with my T70 on mine though where it would go lean and would show 0psi when it should've been pulling vacuum, then inch it's way past 0 and start sputtering kind of strange. Get a tune, that's the bottom line, don't test it with forced induction.
