What rear gears = M6 + turbo
Old 06-16-2006, 02:53 PM
SSShow's Avatar
Default What rear gears = M6 + turbo
Well, I have a cam, Lq9 heads sitting at the house. I have the oppurtunity to get 4.10's in the rearend for cheap! The Turbo prospect has been pushed back at least a year. I'm buying a set of coated LT's shortly to be installed as well and was wondering if I would regret the 4.10's once the turbo (STS t67) was installed. Most sign's around the forum tell me not to do it so I figured I'd get some feedback before I pass on the chance. 2002 Camaro SS
Old 06-16-2006, 03:00 PM
hissin'98's Avatar
Don't do it. You wouldn't see full boost by 3500-4000 in second or third gear. Turbos require loading the engine and higher gears shorten the powerband per gear. Stay way under 373s. I'm running 342s but as soon as the 9in gets here, its set with 3.50s. Do some searching on this, you'll finds tons.
Old 06-16-2006, 03:07 PM
RaNsOm's Avatar
yup I've heard the same. Stay with a low gear, like 3.42s and you'll be golden.
Old 06-16-2006, 03:12 PM
SSShow's Avatar
ok, will do!
Old 06-16-2006, 03:33 PM
Mr_president's Avatar
i have 3:50s in my 9 inch and now that i am getting the th-400 with only 3 gears i think i want to go even lower!
Old 06-16-2006, 07:37 PM
2000 Tran Zam's Avatar
id say you could use 4 10's if your turbo was smaller, cause it wouldnt need as much load/time on the engine to build boost on a stock cubed motor, but im using 3 42's in my setup and it works pretty decent.
Old 06-16-2006, 08:02 PM
93formto98T/A's Avatar
I had 342s in my 10 bolt and went to 310s with the new moser 9". I'm loving the tall gearing! Faster spool and more mph per gear!!!!
Old 06-17-2006, 11:05 AM
mdhmi's Avatar
342's
Old 06-17-2006, 11:15 AM
30th t/a's Avatar
im going 3:42s. i got 4:10s now from my previous NA setup and i dont feel the turbos kick untill 3100rpm. my turbos are twin t44's.
Old 06-23-2006, 10:46 PM
67Firebird455's Avatar
4:10's are BS with a turbo, trust me, look at my sig. I plan on running even 3:50 in a 9" with a 27" tall tire, shoot... may go even taller, I'm tired of being out of gear before the turbo even spools up to full boost. I HATE my 4.10's.
Old 06-24-2006, 12:21 AM
Eric Bazan's Avatar
3.42's or 3.23's
Old 06-24-2006, 12:35 AM
1bdbrd's Avatar
would 3.23s be too low for an m6 car? im considering just leaving the gears alone when i get the car running and it was an original 3.23 auto car.
Old 06-24-2006, 12:36 AM
I really don't know if it would be... Depends on if you're leaving on a 2-step or not I guess... I may eventually put a 2-step on, when I get a 9" under it...
Old 06-24-2006, 01:05 AM
1bdbrd's Avatar
no 2 step for me. in fact im planning on slipping the clutch and nailing it through second as i care more about trap than et (mostly from a street racing standpoint but traction breaks things too... lol)
Old 06-24-2006, 01:07 AM
hehehe, that's what I did to avoid breaking barts... run it up to about 3k, then let her slip, when I'd do that with the turbo it'd make so much damn boost fast cuz the engine was still under load but then the tires would go up in smoke as I progressively loaded the engine more with the clutch. There's a fine line on traction and boost, trying to control it with the clutch and throttle at the same time makes it a little tough, not like an NA car. =)
Old 01-17-2012, 05:29 PM
IgottaT/A's Avatar
how do 3.73's run?
Old 01-17-2012, 06:15 PM
forgedlt4's Avatar
im running 4.11s with a 28 inch tire. my turbo set-up spools extremely fast, so i have zero issues with them. i like em.
Old 01-17-2012, 06:40 PM
WS6HUMMER's Avatar
Had 4.10's (28" tire) when I ran an M6, even did it with my TH400 (which sucks by the way). I now run a 3.50 gear in my 9"(as recommended by my converter builder Lenny) , its a match made in heaven and works great. The weight of your car comes in to play a lot too, if my car wasn't such a pig I'm sure I wouldn't be running a 3.50, I might be closer to a 3.08. My point is that I wouldn't go with too numerically low of a gear, keep getting some feedback on this thread & research,IMHO.
Quick Reply: What rear gears = M6 + turbo
