Oil ? on turbo setup...
OK...so im doing my own turbo setup on my 99 LS1 camaro with a rear mount T70 and was just wondering if i needed to do a low and hi seting on the oiling setup...the oil pump im useing is
Mocal Differential / Rear End /
Transmission / Oil Cooler Pump
Flow rate 1.0-2.0 GPM and up to 54 PSI
WT 3.5 lbs.
3/8" NPT fittings
8 amp current draw
WT 3.5 lbs.
3/8" NPT fittings
8 amp current draw
