Optimum Turbo Street 6 speed Setup?
I am just curious what you guys would consider the best street turbo motor setup for a 6 speed? Say your horsepower goals are 800rwhp MAX on pump gas. Which motor would you choose? 346 LS1, 364 LS2, 370 LQ9, 402 LS2, or 408 LQ9. Say this motor was going in a C5. Also try to guess how much boost you would need for each to reach 800rwhp MAX on pump gas. Assume optimum heads and cam.
346ci LS1=xxpsi=800rwhp on pump gas
364ci LS2=xxpsi=800rwhp on pump gas
370ci LQ9=xxpsi=800rwhp on pump gas
402ci LS2=xxpsi=800rwhp on pump gas
408ci LQ9=xxpsi=800rwhp on pump gas
Which would you consider would give you the most enjoyment.
Senior Member
The bigger the motor, the bigger the turbo needed. With a 408, youd need a 88mm to feed the air requirements and thats a BIG turbo to fit in a Vette. Id stay with a 346 LS1. Its proven to hit that mark many times with a T76 with meth. PSI, isnt important. Its CFM. A lot of thing will determine the PSi needed, such as intercooler, pipe size, routing, restrictions, etc..
I like option 2, the ls2 364. I know the stock LS2 is strong engine powerwise, and I think a turbo version would be a great setup. Basically same benefits of a 346 with a little extra power.
FWIW, I want that combo for my car in the future, with a good set of heads (maybe AFR) and a well matched cam I think it would make awesome power.
Originally Posted by Country Boy
What does it take to retro a LS2 in a LS1 chasis?
Bigger is better for a street turbo motor IMHO. More cubes mean quicker spool and better off-boost drivability. I'm very close to starting a 444 inch build now that blew my 414 incher. If 414 is better than 360, then 444 has to be better than 414.
Befor I even used the motor
LS1 Tech Administrator
A smaller bore will be less prone to detonation. This is one of the reasons the Mod Motors do so well on boost. I'd say either 346 or all stroke 383.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
LS1Tech Co-Founder
What I would build and why...
+408ci, 8.5:1 compression
+AFR 225's or comparable head
+Twin 66mm turbos
+LS2 90mm OEM intake
I'd go bigger turbos becaus a little lag would be a good thing, my 02 Z06 on drag radials would be a deathtrap if it made crazy midrange power. And you can't fit a big single front mounted turbo on C5's.
+Twin 66mm turbos
+Twin 66mm turbos
+Twin 66mm turbos
