Fuel flow requirements
Old 10-09-2006, 09:02 AM
sparkwirez06's Avatar
Default Fuel flow requirements
I have stock 98 vette fuel rails,-6AN feed and return lines,stock rail mounted regulator, 60# injectors, 255 fuel pump, Will this supply enough fuel for my stock block LSx with pt76gts turbo, 6-8# boost meth/water injection? THANKS
Old 10-09-2006, 09:16 AM
BoostedWS7's Avatar
how much power u figure u will be making? im thinkin u prolly will be alright, but might need a bigger or another pump on top of what you already have.
Old 10-09-2006, 09:26 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
A Kenne Bell Boost a pump surely will not hurt. I have been running a BAP for a few months now with excellent results.
Old 10-09-2006, 01:10 PM
John_D.'s Avatar
Should be plenty. That's basically the same setup I have on mine. I don't have the AN lines (the stock v6 feed line is the same size but the return line is smaller). I'm also running a BAP but haven't had to turn it up yet.
The most restrictive parts were the two quick-connect fittings I used on the line at the engine. Checked those a couple of weeks ago, and they necked down to 1/4" where the rubber line slips onto the fitting. So I opened those back up to almost the full 3/8" again (by drilling them out).
If you're using methanol, which provides part of the fuel enrichment, that takes some more load off the fuel system too.
Old 10-09-2006, 03:29 PM
Maybe 550hp, will probably upgrade later, fuel rails, regulator, bap, forged pistons, and turn up the boost!! THANKS,
