oil drain question
Old 12-12-2006, 03:40 PM
SINISTER's Avatar
Default oil drain question
custom ste up yadda yadda 6.0 manifolds cross over all love
designed for t-76 and i can fit much bigger only question is
if i go with a bigger turbo s88 or such it will lower the drain just a hair that at where it drains into the pan may be a slight up hil...but it will be coming right out of the turb at a good 45 degree..
you think ill be ok or im gonna smoke...
dont wanna run a pump...anything out there other then the pump to add a lil pressure to the line to make sure the oil goes all the way in...
