oil drain into oil pan right underneath timing cover
Old 12-21-2006, 11:43 AM
2002/Black/SS's Avatar
Default oil drain into oil pan right underneath timing cover
i know someone on here has this picture, their oil return is in that thin part of the oil pan right underneath the timing cover. im doing it that way so i really need to see that picture!
also will my oil drain freely if i have a straight fitting coming out of it and it goes straight to the turbo up where the battery is??
last question, is it a MYTH that the oil pan can come off with the engine still in the car, i jacked the engine up by the crank pulley and it still didnt look like it gave me enough room
Old 12-21-2006, 12:00 PM
phildo's Avatar
Here is a link to a camaro that has the drain like you want. www.calibercustoms.com
If you put grease all over the drill bit and tap you will have really no metal chips in the pan. The grease collects the shavings. Also the hole will be big enough to look in and get any that do go in. Just take your time and drill slowly.
Yours should drain fine just use no smaller of a line than -10. But there is still no guarantee I will drain enough. If it does not work than run a scavenge pump.
Old 12-21-2006, 12:02 PM
LS1PoweredZ28's Avatar
Getting that oil pan off with the engine in the car is a pain, but it can be done. You have to jack up the motor and drop the k-member about an 1-1.5 inches. Do a search on rod bolt installs and you can see how people have managed.
Kevin
Old 12-21-2006, 12:04 PM
Jake@EPP's Avatar
We welded in a -6 bung into the pan over by the driver side motor mount to have a oil return for a customers STS. Works alot better then a flimsy oil cap.
Old 12-21-2006, 12:09 PM
bowtieman81's Avatar
Hey buddy, that was me. That was a while ago, let me do a bit of digging and find that thread with the pics.
Old 12-21-2006, 12:46 PM
i knew it was someone, i think Mr. presidents has it that way also, im going to do the oil drain tonight, so id really appreciate it!
Old 12-21-2006, 01:02 PM
phildo's Avatar
Here it is. It was in the link I gave you.[IMG][/IMG]
Old 12-21-2006, 01:04 PM
i looked for it in the link and i couldnt find it, thanks! the only problem is that looks smaller then -10
Old 12-21-2006, 05:34 PM
Here is my thread with the pics. Hope that helps.
https://ls1tech.com/forums/showthrea...&highlight=tti
Old 12-21-2006, 05:38 PM
Josh@KY-Turbo's Avatar
Why not just pull off the timming cover and put your fitting there? Is the turbo to low for oil drain back with the fitting that high?
Old 12-21-2006, 05:56 PM
TT-TECH Veteran
Inspector12's Avatar
Same place the Vortech kits have you place their return line and it was about an -8 or -10 in size.
Old 12-21-2006, 06:17 PM
i bought a -10 straight NPT fitting today, im going to see if i can fit it on the oil pan under the timing cover
Old 12-22-2006, 04:42 AM
EPP
EPP's Avatar
Smile
Here is where we installed the return line recently on a Camaro SS. Bob
Old 12-22-2006, 12:18 PM
MiaSSmaro98's Avatar
I Bought A New Pan From Gm And I Think Its Smaller In The Front Then My Stock One.i Have A 12an To 3/8npt Straight And It Wont Work On The New Pan But Will On The Stock Pan Still On The Car
Old 12-22-2006, 12:39 PM
Greg Fell's Avatar
I thought the return was supposed to be higher than the oil level?
Quick Reply: oil drain into oil pan right underneath timing cover
