My Custom STS exhaust version 1
Overall I would have liked to tuck the pipe going accross up higher but it does such a great job hiding the turbo I am going to leave it.
What your seeing is my dual exhaust off the turbo. It is somewhat modular in that I can unbolt it all and run wide open. I can unbolt one half and run thru 1 muffler cutout capped and vent the wastegate to the air. (Sounds so much better with the wastegate muffled BTW) Or run with the cutout open, or run the whole thing like I do but it's still easy to remove if need be.
There are things that can / could be done better. IE tuck the pipe higher, get the tips to exit more evenly, etc... Someday that will get done. Also where you still see non black pipe that will get painted as well to further blend in.
Overall I love it. Car sounds like a mild cat back with a turbo now and not a big ol whistle tip. woooo woooo. Much much quieter than a dump or the single exit, no muffler setup they provide. Sound levels are equivalent to when I had my dynomax ultraflow on the car. Very reasonable.
Oh and also you can see my custom discharge pipe I made out of an old Y pipe. I still need to make a hanger for it and I can pull it up another inch or two but even as is, zero ground clearance issues. Whole lot less bends, no dinky pipe coming off the turbo, etc....
Enjoy.
I really wish that STS would work this out a bit themselves, as that is a big drawback in these cars [noise]. Don't get me wrong, when you are allowing someone to experience the boost, they are BEHIND you, and get to hear the sound...which is cool. I just don't want to listen to it when cruising around at lower speeds when it is most noticeable.
when I got the kit way back when the dinky pipe going up over the axle and such seemed like such the restriction to me. Well with the power that folks are making I can see its not much of any of one but I made the pipe so I am using it.
as for power have not dyno'd it yet. will probably do so in a few weeks.
Kalifornia doesnt say anything about STS systems or do people just take them off for IM?
J - I have been screwing around with the tunes so much I haven't even taken it to get dialed in on Synergy's dyno yet. As of yesterday I am playing with our bastardized 2 bar. More than likely will take the plunge on the maftpro and call it a day. So after it's all dialed in I may hit the track at least once. I am a very poor drag racer though. My best 60' to date is 2.4 when I had the Powerdyne, but it did go 117mph
I am getting drag nittos though since all street tires do is spin now so maybe I can pull off a 2.0 and a sub 13 timeslip
Having fun with the 2 bar hack yet...i'm still having fun with new tunes everyday to see what works and what doesn't.
J
So you finally got it painted like you described. You guys are true master craftsmen. BTW, Rick at Synergy ended up painting the mufflers for my STS TT system. I will take some pictures when it stops raining. Thanks again for convincing me to install my turbos.
Lewis
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
