Hi-flo problems, go figure! (pics)
the crossover is hiting my powersteering lines, i bent the **** out of them and they still hit it, im really pissed. and i cant figure out what to do and im afraid i mesed up the lines by bending them. how much can i really bend them???
3 pictures of the lines hitting the crossover:
AND as u can see i bent the **** out of them:
and here is the crank to crossover clearence (not to bad):
Have you considered whacking the crossover with a hammer to create some clearance ??
Can't you put a "dent" into the area of the crossover pipe that's a problem?
Originally Posted by Turbo LS1 SS
BEND those.....i have my lines infront of the alt.....put some more muscle into it...lol ..... then wrap them. you will be fine.
i had no problems with that crossover clearance
=/ Kits really should be "bolt-on"
This is somewhat of a joke... but, its not as big of a deal as you are making, just bend the lines out of hte way, I had to on my kit. Your car was never designed to have a big ole turbo and a bunch of exhaust pipes under the hood. lol
You're putting a TURBO KIT into the engine bay that's barely large enough for the motor itself. You should pretty much expect having to tweak things here and there. This isn't like installing a Tornado in your intake tube, this is a real modification
You'll be perfectly fine, those lines bend relatively easy. Just don't bend them back and forth over and over again too many times or you'll run into some issues. They really are made of that material to be able to flex SOME. Other than that it looks good! Let us know how it works out!
