turbo kit destoys belts
i have a problem with part of my turbo kit its similar to the tti street kit. it gos through belts because it hits the thermastat housing.which i ground down to make room for the belt ..im guessing it the brackets for the altinator. anyone have this problem with kits like this im sick of changing belts
Sounds like its a design issue with the bracket. Tiff doesn't have that problem with her QMP-style kit, but I built the alt. bracket from scratch and made sure the belt is well clear of the thermostat.
6 Second Club Moderator
Originally Posted by andereck
What?? A turbo kit is killings belts? I though you turbo guys liked to bag on blower guys about their belts. This is funny ****!...well maybe not to jason02Z.
I've never replaced a belt. I guess it's the kit you buy.
which alternator bracket do you have?
if they are off just a slight bit they can throw a belt or chew one up. I have made a couple that were off just a slight bit, i had the people send them back to me and i re-aligned them and they reportably work better then
the one i use for my self is close to the thermostat housing but does not touch, also i have noticed some thermostat housings are slightly different from eachother, the one i got from autozone is smoother and has more clearance from the belt.
any pictures of your problem?
