i have a couple STS Turbo questions.
Old 01-18-2007, 09:47 PM
CHIWS6's Avatar
Default i have a couple STS Turbo questions.
what do u guys recommend on upgrading on this kit? what changes do i need to do the car as is besides the cam btw what kind of cam would i get for the turbo? would u recommend an intercooler? any usefull info would help out , thanks in advance
heres a list of what i have on the car right now:
Engine: MTI clear Lid, K&N Filter, NGK Tr6's, MSD 8 mm wires, Racetronix fuel pump & 42lb Injectors, TB By-Pass, 160 T-Stat, G5x3 114, PRC Dual Spings, CM Pushrods, ASP Crank Pulley, Pacesetter LT headers w/Ory, Borla adjustable catback with electric cutout, FAST 90 mm intake w/ NW 90mm TB, Harland Sharp roller rockers 1.7, thunder racing maf ends, nos 5177 kit(which i never even finish installing) with bmn gear lockout controller
Trans: Pro 5.0 Shifter, Spec 3 clutch, Harlan Shift Light.
Chassis/suspension: All BMR- STB, SFC's, LCA's, Adj. PHB, Adj. Torque Arm, D/s Loop, hal 12 way adj shocks package. Moser 12 bolt/ 4.10
Old 01-19-2007, 05:08 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...Car.php?car=32
Check this Camaro SS out for some info that may help you. Bob
Old 01-19-2007, 08:29 AM
NYSS Guy's Avatar
Unfortunately for you, a lot of what you put on the car is either going to go away, or won't be too helpful. The lid, filter, catback, cutout, maf ends, and nitrouc would have to all come off. The long tubes could stay, but I've heard they don't help much for the sts setup.
I'm not that good on cam specs, so I'm not sure if your cam will work well or not. How much boost did you want to run? Anything over 5 psi, you will need something to cool the intake charge (intercooler or methanol). Other than that, running 5-8 psi with an sts kit is pretty simple. Obviously you'll need a new tune, which is the most important part. HTH.
Old 01-19-2007, 08:31 AM
NYSS Guy's Avatar
Oh, just noticed, your sfc's....one side will come off. Also, those 4:10's in the 12 bolt aren't ideal. You might have a touch time spooling this thing up until late 2nd/3rd gear.
Old 01-19-2007, 06:17 PM
CHIWS6's Avatar
thanks for the info, what kind of gears would i need, 3.73 or 3.42? any other info would be appreciated
Old 01-19-2007, 07:53 PM
NYSS Guy's Avatar
I run 3.42's. I think anything above that won't work as well. Good luck with the build.
Old 01-19-2007, 07:58 PM
CHIWS6's Avatar
what kind of boost can i run the car with a stock bottom end? in case i decide to go with the sts, should i upgrade the turbo? if so what be the right choice for a street/strip combo? is a intercooler require if i will be running low boost? btw thanks for the info man!
Old 01-19-2007, 08:54 PM
Schantin's Avatar
Borla, cutout, lid, MAF ends....sell. You'll have to remove the driver side subframe connector too.
Cam....what are the specs? I'm running a TR224 on a 112LSA and it actually works decent. Not ideal, but decent.
STS. I'd upgrade to the GT-67 turbo.
Definetly add a FMIC. I don't care what BS STS throws out about the intake cooling the charge. My IAT's were hitting upwards of 130 degrees at 5PSI. After the FMIC, it dropped to 100 to 104.
I'd say keep the LT headers, especially if they're ceramic coated. I have DynaTech LT's and no issues. Wrap the exhaust from the Y-pipe back and you'll get better spool times + the benefit of the LT's at lower RPM's. My $0.02
The 4.10's won't help you either. 3.42's are a good choice.
Solder the wiring connectors from the STS to the PCM. Also want to section the upper radiator hose for better clearance + add heat resistant tape to the intake pipe where it comes close to the driver side header and the upper radiator hose.
Get a good tune....and that's about all that comes to mind.
Old 01-19-2007, 09:10 PM
GotV-8's Avatar
3.55's will work. You could do 3.73's too. Boost I wouldnt go over 8psi with the stock block. Anything over that and you will be pushing it.
Old 01-21-2007, 06:52 PM
CHIWS6's Avatar
thanks for the info fellas!
ttt for any more info
Old 01-22-2007, 08:18 AM
Letsndy's Avatar
do a front mount!
Old 01-22-2007, 10:36 AM
JAvenger007's Avatar
get a hold of TRT (texas rear turbos) for the purchase. Not only do they have great prices on kits, but they also sell their own FMIC setups and other configurations. On top of that, some of the best customer service youll ever get.
You can also open search and simply adjust to "thread titles" and type "sts". Youll find everything you ever wanted to know.
Old 01-22-2007, 11:27 AM
99Z28LS1's Avatar
be careful on the psi.... if i made my original 7.5, i would be way in the limits of the stock bottom end. you dont need 8 psi when the right combo on 5.5 will get you over 500rwhp
Old 01-22-2007, 03:53 PM
How did you make 500rwhp on 5.5 psi?? Thats the highest numbers ive ever seen on that much boost with stock ci. and stock clutch??
Old 01-25-2007, 12:08 AM
GhoSStrider's Avatar
Yeah. That's pretty impressive.
Old 01-25-2007, 12:14 AM
trtturbo's Avatar
The car does run very well. He was around 450ish before we did the cam with someone elses tune. We installed the cam and retuned and made the 500.
Cam works well.
Old 01-25-2007, 12:19 AM
Cam works well.
Any idea what the specs are on the cam?
Old 01-25-2007, 09:31 AM
99Z28LS1's Avatar
and the builders speak..... ha ha. car made 472rwhp on stock internals and 7.5psi. shes currently ar 5.5-6 MAX. its good at where its at, i dont want her going boom while im waxing a new C6 Z06 or something
Old 01-25-2007, 09:33 AM
99Z28LS1's Avatar
TRT might give you the specs if you pm them
Old 01-25-2007, 07:35 PM
magius231's Avatar
I'd be interested to if they don't mind posting specs on it...
Quick Reply: i have a couple STS Turbo questions.
