ProCharger C5 StageII Belt/Pulley matrix
I know this will get lost in the archives as this forum moves quickly but I created a Belt/Pulley matrix for any of you that may be using the ProCharger C5 StageII system.
Thanks for posting bro-that's some good reference info to have. It says the stock crank is 7.375-isn't it 7.5"? And on a side note-what kind of results/ feedback have you been having on the new stage 2 ATI C5 bracket? From what I have seen and heard it makes swaping/replacing belts a breeze? The A&A bracket I have works well but if you need to change a belt it takes alot of cursing and swearing! Also is the bracket set up differently for 6 and 8 rib?
Thanks!
Thanks!
You know I have never measured the balancer myself and the above information is from engineering. the ATI PerfProd balancer is indeed 7.5" in non-underdrive form but I'm going to stick with 7.375" for now.
The StageII bracket has been sucessfully used with F1R blowers in 8 rib configuration with success, and yes it is more convenient to replace the belt with the ATI part when the need arises.
The 8 rib setup uses a taller "tower" and longer spacer with the appropriate idler pulley but otherwise its the same unit as the 6 rib. ProCharger has the appropriate accessory pulleys for the conversion. You only need to procure an ATI 8 rib balancer.
Thanks for asking!
Thanks for asking!
