Please help with turbo size on 408
Old 03-27-2007, 12:20 AM
Jimmy P's Avatar
Default Please help with turbo size on 408
This is for my buddys car. Had a forged 347 LS6 with a 71 mm Precision turbo using the Hiflo Kit. The motor blew, so he is going to upgrade to a TSP 408 iron block, probably 8.0:1 compression. He will be ordering the motor tommorow. What size turbo should he go with? Entire car is built, suspesion, fuel system, th400 trans, etc. Car will see both street and strip. Any recommendations on what size turbo to go with and were to buy it from? Thanks
Jimmy
Old 03-27-2007, 02:17 AM
Juiced's Avatar
alot depends on what his trans can take as far as input tq.... Either a large frame pte or medium frame s88
Old 03-27-2007, 03:21 AM
black98ws6ta's Avatar
It really depends on his goals, what kind of power he wants to make and how much he wants to modify the kit. Once you step into a good flowing 408 motor and you want to make power you need a large frame turbo.
Old 03-27-2007, 07:27 AM
Navy David SS's Avatar
Twin T-67's
David
Old 03-27-2007, 08:37 AM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
For a 408 he will need alot more then that billet 71mm comp wheel can put out. We are talking 85mm to 88mm if he wants to carry it out to the redline.
Jose
Old 03-27-2007, 10:32 AM
Nate81Camaro's Avatar
Is he wanting to go TT or a big single???
Old 03-27-2007, 10:49 AM
cablebandit's Avatar
sounds like he is using the hiflo kit again so i guess he is limited to a t-4 88 at best or a 76
Old 03-27-2007, 10:51 AM
Juiced's Avatar
call jose about the t4 flanged s88's they were working on.
Old 03-27-2007, 11:00 AM
HOLY HUGE TURBO!!!
I got wood!
Quick Reply: Please help with turbo size on 408
