New Dyno#'s - WTF is Going On?
Old 04-06-2007, 07:58 PM
01Bird_of_Prey's Avatar
Default New Dyno#'s - WTF is Going On?
http://i172.photobucket.com/albums/w...prey/dyno2.jpg I've been chasing this problem for almost 2 years- I can't seem tomake over 700rwhp.
Originally,I spoke to Speed Inc about this issue and theysaid that the stock twin intercooler could be a restriction so I had a custom Spearco made and it didn't fix the problem.
Then it was the springs on the heads - fixed that, but still the same issue.
The problem is that (see below) at the top of the run (after 5800 rpms) it stops making power - there is no belt slippage, at least not enough to create this problem.
I'm beginning to wonder if it is just out of cfm- my set-up is a 410ci, afr 225, FAST intake 90/90 throttle body, cam 224 232 .581 .595 114.
I need some opinions about what the problem could be - It's driving me CRAZY!
Old 04-06-2007, 08:07 PM
ninetres's Avatar
ahhhhhhhhhhhhhhhhhhhh.....
the graph you posted shows over 700 rwhp. The tq is 69X.
raymond mckinney's Avatar
Damn its been along time since i've seen u around town!!
Old 04-06-2007, 08:08 PM
Someone told me u got a G35, I about cried!
Old 04-06-2007, 08:17 PM
My goal has been to make @ or over 800 rwhp but no matter what I do I stay around the low 700's I even tried a 75 shot of nitrous and only picked up 20rwhp (on the old set-up). So somethings wrong.
Old 04-06-2007, 08:19 PM
Lies all lies - no just kidding - I was looking at buying one until I test drove it. I told the dealer that it seemed pretty slow and he slammed the hood and went inside - so that was the end of that.
Old 04-06-2007, 08:22 PM
btw, the air/fuel on the graph is not exactly right.We were using the wideband on the BS3 the car has a cutout and the wb was in the rear.
Old 04-06-2007, 08:24 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,110 Likes on 728 Posts
What tensioner setup are you running?
Old 04-06-2007, 08:37 PM
The sdec spring setup with a 3.4 pulley
Old 04-06-2007, 10:42 PM
Blownramair's Avatar
hmm I made 15psi (d1) with a 3.7 pulley... something not right...
Old 04-07-2007, 06:48 AM
2001WS6Vert's Avatar
His xtra cubes will swallow a couple #'s. I say you need a bigger blower.
Old 04-07-2007, 01:18 PM
SVC707's Avatar
that doesnt make sense either. im running a 408 with afr 225's cam motion custom ground. @ 9psi im at 707hp 640tq on a D1SC
Old 04-07-2007, 01:29 PM
98turbls1's Avatar
How's the tune??? I would say that is probably what's going on unless there is a mechanical issue that we're not seeing...
Old 04-07-2007, 01:33 PM
NoGamesLS1's Avatar
Your not slipping a clutch are you bro?
Old 04-07-2007, 02:05 PM
cws T/A's Avatar
Cam looks small for a stroker
edit: Then again you have 600ft/lbs from 3750 - 6250rpms
Old 04-07-2007, 04:08 PM
DeltaT's Avatar
Looks like you might have a little power left in your upper end by leaning out your AFR to more like 11.6-11.8. I wouldn't be surprised if you picked up another 20HP easily.
You have some good numbers already, though...
Jim
Old 04-07-2007, 04:13 PM
Senior Member
Country Boy's Avatar
The grapgh doesnt look like its maxing out. I would assume that if the head unit maxed out, you would see a good fall off at some point and the HP and TQ curve look steady. Are you running a 2/ 3 bar speed density setup?
LS1Tech Sponsor
Slowhawk's Avatar
I'm going to say that the compression is too low.The Cam is too small and the blower is too small.That Cam would peak hp at 5400-5600rpm NA.
Old 04-07-2007, 04:41 PM
SVC707's Avatar
im with the cam too small. when first getting mine built everyone said my cam was too big. not anymore..... i know the D1 will max out on my setup but be it i see 707 w/ 9psi on the 4.00" pulley im not even gonna worry about it. talk to cam motion about getting yourself a new cam first is what id do. im on a 24x/25x
Old 04-07-2007, 04:56 PM
lasvegasgs's Avatar
Maybe its time to rebuild the blower? I read that somewhere on corvette forum so guy couldnt make over 480rwhp on 8psi or even on 12psi. ended up selling the blower and getting a new one.
Quick Reply: New Dyno#'s - WTF is Going On?
