boost on a 3 bar fast unit ?
what happens when boost goes past the limits of a 3 bar map sensor on a f.a.s.t . aftermarket comp.? its the old style box......will it still work?
i need to run more then 30psi and the fast computer and map sensor are good to only 30.........i think.........please help!!!!!!
the sensor will be maxed out and the computer wont know how much boost its getting. Its kind of like having a MAF car with the MAF maxed out. You can trick it into fueling with the VE, but it can be a gamble.
p.s. a three bar sensor is good up to 28lbs
Holy crap if this is in a LSX combo... Good luck man
[QUOTE=coop5885]the sensor will be maxed out and the computer wont know how much boost its getting. Its kind of like having a MAF car with the MAF maxed out. You can trick it into fueling with the VE, but it can be a risk
so i can keep it fat at the end of the table and the computer will go with the last VE settings? and as long as the car doesn't lean out under a few more psi it "should" be ok?
