Anyone running a meth injection kit please chime in!
Old 05-19-2007, 08:55 PM
BLOWNBLUEZ06's Avatar
Default Anyone running a meth injection kit please chime in!
Ok, I have a Maggie with a 3.1 pulley. I have considered spraying it, but for many reasons am leaning toward a meth and water injection system. I have looked at a few systems and like the sound of the Snow Performance stage 2 system with the added valve to allow the use of the windshield washer fluid bottle. I want to put the timing back and put a 2.8 pulley on it and would like to hear what systems you guys are using and any comments / suggestions / regrets you have about your system as well as the performance results. Thanks
Old 05-19-2007, 09:04 PM
eb02z06's Avatar
I'm running meth on my Z06 but I log the air temp drop after the meth sprays in the motor. I just don't know beneficial the meth is as it gets compressed by the maggie? I would only consider the Alky control kit.
Old 05-20-2007, 12:36 AM
gametech's Avatar
LS1Tech 20 Year Member
Don't spray a mix with the Maggie, spray pure meth. Your IAT's probably won't be high enough to flash vaporize the water in a WW mix, so you will bog. Pure meth will almost certainly vaporize, eliminating this problem. Of course, every combo is different.
