New Car New Build PART 2
. The alternator relocation bracket I bought from Smokin Hawk wont work with my NASTY N8 fuel rails at all. I have a set of Speed Inc rails on the way, but who knows if they will be any better or not. The turbo demons stike again. So far all I have left is a couple relays for the fuel pump and fans on the FAST XFI system, Mounting the Spohn rear sway bar, fluids, belt, hoses, and clean up before being able to start the car. Oh yeah, and the alternator situation. So close yet so far away.
Okay I ordered some more fuel fitting and all my vacuum hose today. I had them next day aired to me so I should have them tomarrow. Hopefully I can stay on schedule and have the car runnign by Saturday afternoon.
Ive had a couple people tell me they had to cut 2" off the end of the fuel rail and then re-thread the end....
Kyle
Kyle
To add to my day, my Sphon rear sway bar gave me trouble too. It was my fualt though. I have to order some new bushing pads and u-bolts.
I should have all my fitting and vacuum line in tomarrow. Hopefully I can get the majority off the little things done and finish up Friday.
J
(I will try get some pics up soon of the progress.)
I fixed the alternator situation with the custome mount in the pic below.
Here is where the turbo setup is at as of tonight. 90% finished. I have to run some vacuum lines and clean up some odds and ends, but I am close.
Here are a couple of under car shots.
My FAST XFI mount and wheels and tires.
On a future note. Latter in the year the car will be completley taken back apart to have a cage put it and be completely re-wired. It is going to recieve a 408 with AFR 225's and twin TC76BB turbo's. I will be shooting for a HP goal north of 1200rwhp and it will be a true drag race setup that will remain street leagl, though I highly doubt it will be streetable.
my recent designs moves it out and completly out of the way of the fuel rail.
if i knew you were having problems with it i would have tried to help you out and maybe switch your old one with a newer one or something, looks like you got it taken care of though.
I might switch to a T4 T88 soon. I will try the T76 out at first, but if it can't feed 20psi at 7k rpms.....then I need to look at new plans.
It was not big deal really. The first one I got from you worked great on my 98 Z28. This build is a little more hard core. I appreciate the fact that you were willing to help take care of the issue.
Yeah the full spool will tear up a set of DR's. I would have gotten the MT 315's DR's if they had been out when I ordered the BFG's. The MT's will be the next tire on the ZR1's
