blowing out the dip stick under boost!
Old 05-20-2007, 10:46 AM
Roast1's Avatar
Default blowing out the dip stick under boost!
yesterday i took a drive and i got on it a little and i noticed that my car was smoking(blueish/white). pulled over and found that my dipstick wasnt all the way in and it had shot oil out on to the hoodand engine.pushed it back in and decided to put in some check valves in the pcv.took it out again and at 5psi of boost i blew out the driver side valve cover gasket. whats going on.
Old 05-20-2007, 12:04 PM
engineermike's Avatar
Broken pistons. Do a compression check.
Old 05-20-2007, 12:08 PM
WestSide's Avatar
what kind of PCV setup are you running?
Old 05-20-2007, 12:12 PM
fullthrottledan's Avatar
do you have a catch can?
Old 05-20-2007, 12:26 PM
HUNTER02SS's Avatar
I would vent your pcv system to atmosphere and if it still doe's it then check your compression.IMOA.
Old 05-20-2007, 01:45 PM
BigBenz's Avatar
kinda mean lol. do you have that tube above the big pvc line capped off? also you need to put a filter on the oil fill.
Old 05-20-2007, 03:13 PM
EPP
EPP's Avatar
Smile
http://www.exoticperformanceplus.com....html?item=756
We use these valve cover breathers where the oil fill is located. Bob
Old 05-20-2007, 06:10 PM
dschmittie1's Avatar
mine was doing the same thing. put breathers on the valve covers and it smoked all the time. Cylinder leak down test results were no good so I tore the motot down to find 4 cracked pistons
Old 05-21-2007, 05:25 AM
TT-TECH Veteran
Inspector12's Avatar
Hate to tell you this, but this guy is right that is way to much blow by to be a PVC issue. You have a piston issue an ring gland probably lifted very comon. Do a compression check like he suggested and it will tell you for sure which one or ones. Good luck.
Quick Reply: blowing out the dip stick under boost!
