wastegate effecting tune??
Old 05-24-2007, 01:43 AM
SR-71 SS's Avatar
Default wastegate effecting tune??
I have a 98 camaro, procharged at 15 psi. The inlet hat fell off and dragged, ruining the wastegate so I switched from the one that came with the D1 kit originally to a Procharger Pro-Flow I got from EPP (thanks guys). Previous to this I had just gotten the car tuned with the old wastegate. When i test drove it I was keeping a eye on the AFR and it was showing way lean so I got off the boost. Would changing just the wastegate effect the tune? Either way I will be retuning cause my last clutch fried at 4700 rpm on the dyno ( 550 rwtq and climbing ) , but was curious. thanks to all
Old 05-24-2007, 12:05 PM
Silver02Z28's Avatar
Exhaust leaks before the WB will show a false lean. Where is your WG in relation to your WB? Is the WG gasket ok, bolts tight?
Old 05-24-2007, 12:13 PM
y2khawk's Avatar
umm, do you mean bypass valve?
wastegates go in the exhaust for a turbo
Old 05-24-2007, 12:27 PM
LS1TECH Sponsor
DrTurbo's Avatar
Correct......no wastegate on a blower car.
Old 05-24-2007, 03:08 PM
SR-71 SS's Avatar
sorry, yes its a bypass valve
Old 05-27-2007, 10:32 PM
SR-71 SS's Avatar
any thoughts?
Quick Reply: wastegate effecting tune??
