people with multiple nozzles on their methonal setups
I want to run two nozzles on my meth setup
When I ordered the Snow Performance Stage 2 gas kit it was back ordered 2 weeks, but stage 1 kits were in stock so I picked up a stage 1 kit as well
will there be any problems running both kits in parallel?
I'm thinking of having the stage 2 kit come on first because it has a progressive controller then get a 10psi switch and fire the second kit around there, maybe even 15psi for the second kit
you can do as you described. But having to mount 2 kits would be a hassle. the pumps on most meth kits have more than enough flow to support 2, or even 3 nozzles. What you can do for your 2nd nozzle if you like is use a nitrous fuel solenoid on a hobbs switch, just tee into it. or just tee into the one line for the 2nd nozzle. you would be spraying an insane amount of meth with 2 pumps running. Im assuming you are going to run dual M10 nozzles? if so just step up to one M15, or dual M15s, the pump should keep up.
Gary
Gary
