PIcs of my 408 F1R, Becool setup
Just wanted people to see the setup. I'm running 4" 90 on the SC intake, with the Becool Rad.
Well the #'s are based on 12 PSI boost and 6000RPM. 750RWHP 600-700 trq. She was spinning on the Dyno from what I was told so I really do not know what she has in her. I'll be taking her for the final tune sometime next month. I fully expect to make well over 800rwhp. I just wanted to show the 4" 90 and Becool setup and how it all fit. If anyone has any other questions chime in and I'll get a pic of any specific areas that I modded.
Single Spal 16 incher. I actually notched the sides of the hole, this allowed the condensor to move forward through the gap. I then cut off the lower "lip", this allowed the radiator to move forward as well. I also cut the top support with the intention of standing the radiator vertical, but in the end I did not need to. I had to build a custon shroud to cover the radiator and to hold the top at the angle as seen in the pics.
Thanks for the props guys, as far as stealth goes.... aint happening here She's a full weight car, I believe she is in the raange of 3600-3700lbs (correct me if I'm wrong), I want to be able to run consistant 9's and pick up some 'Ol Roy at Walmart
im on the rence with the prochager deal. this 500HP is fun but im think of gettin some patriot stage 3s and a procharger in the hops for 800RWHP. with my pistons and those heads ill be 9.9:1 think it will work?
congrats man looks sweet!!
