Best Cam for STS turbo setup?
Old 07-02-2007, 03:27 PM
00TurboTA's Avatar
Default Best Cam for STS turbo setup?
Would it be the best to go with a custom ground cam or a pre ground cam? (kinda like the MS3 thread but not)...
Old 07-02-2007, 03:52 PM
hissin'98's Avatar
well, customs are about the same price so like i did, I researched a lot on my combo and talked to a few different people from different companies and kinda did a happy-medium between them. It's gonna be a smaller grind than you think. Mine is a 222 .563 114 comp cam
Old 07-02-2007, 04:22 PM
ZL1Killa's Avatar
custom grind cam. thats what i'm going to do and it will more benefit you.
there is Patrick G up here (Patrick Guerra i think) and other people. I'm going custom but going to see what I make with IC and 7psi first. still got the stock 01' cam
Old 07-02-2007, 06:59 PM
OUTLAWZ RACING's Avatar
TRT does real good with their cam I have an EPP cam very lumpy very good and top end pull but to each his own.
Old 07-02-2007, 08:49 PM
RooRnZ28's Avatar
my cam is from TRT as well. if your gonna tune right after the swap, then definitely go with a custom grind for your application
Old 07-02-2007, 09:34 PM
engineermike's Avatar
If you're going to insist a custom grind, then check one thing. . . If the cam rep doesn't ask you what your backpressure is, then they have no business grinding custom turbo cams. I'd be willing to bet that 4 out of 5 don't ask, or don't know to ask that question.
Mike
Old 07-02-2007, 11:15 PM
LS1Tech Sponsor
Slowhawk's Avatar
We ussually ran a 226/220 on 115 duration Cams on STS cars.346ci at 14lb would make 720-760rwhp with this setup with Truck heads.
Old 07-03-2007, 02:54 PM
JAvenger007's Avatar
ive got a 228/228 going in a few days. ill let you know how it goes with the T67 and 6speed.
Old 07-03-2007, 06:45 PM
99Z28LS1's Avatar
such a nice cam selection
on my stock internal intercooled LS1 with 42lb SVO's and 255 in the back at 5.5-6 psi i made 503 with a 228/228 .588 .588 115LSA and 512rwtq
Old 07-03-2007, 07:07 PM
Websy21's Avatar
That's awesome, I thought of the exactly same cam but 114LSA for my A4 but wasn't sure on how it would work with a turbo system. Guess that pretty much answers my question. Whats the drivailty like?
Old 07-03-2007, 09:16 PM
rojows7's Avatar
what would happen w/ a higher duration say 236/242 and 112/113 lsa w/ a turbo set up
Old 07-03-2007, 09:22 PM
Honestly, I'd like to see someone try it, though i don't think it would work well. Usually, folks choose a cam in that range to go along with a fairly wild turbo setup using a mid-frame 88 or equivalent, that will let the motor rev. With a 67 mm rear mount, the turbo won't let the engine rev where the cam wants to make power.
That's just theory, though. Let me know if I'm wrong. In this case, I'd like to be wrong, because then I could upgrade my own cam. . .
Mike
Old 07-03-2007, 11:59 PM
trtturbo's Avatar
we are doing a Hummer with a 408, TFS heads, Victor Jr. etc.. and we are doing a
236/232 .601 .595 114. May not be able to dyno it, but the owner wants to take it to the track at least once. It should be a site to see; '07 kindof a metallic teal color, 24" wheels, Brembo brakes, 408, 4L80, rear turbo. It should be interesting.
Old 07-04-2007, 11:31 AM
chance575's Avatar
Need some pics, vids or something
Old 07-04-2007, 12:22 PM
PREDATOR-Z's Avatar
Says you have a T60, my choice would be
224/220 113
or a 220/220 112
Old 07-04-2007, 10:53 PM
GhoSStrider's Avatar
What do you guys think about a 224/224 .581/.581 112lsa
Old 07-05-2007, 06:50 AM
PREDATOR-Z's Avatar
Too high of a lift, use XE lobes but the cam will work.
Old 07-06-2007, 12:16 PM
99Z28LS1's Avatar
my cam is larger than that on all numbers...... and my cam is a "mild" cam to some......
228/228 .588/.588 115LSA
Old 07-06-2007, 06:19 PM
trtturbo's Avatar
Old 07-06-2007, 06:44 PM
ThaBirdMan's Avatar
I agree, the 224/224 cam would be a good choice.
Quick Reply: Best Cam for STS turbo setup?
