383 high compression turbo??
Old 07-10-2007, 08:17 PM
12 Second Truck Club
TURBHOE's Avatar
Default 383 high compression turbo??
so how long will a 383 with 10.5:1 compression last with a t67 turbo at 7psi. i ask because my 383 kit has pistons with 2cc reliefs. so i can only get the compression down to 10.5:1. i don't really want to buy new pistons. and what size injectors do i need to be looking at? i'm sure 42lbers won't cut it.
also the pistons have to be special made. this kit uses a 6.2" rod for some reason
Old 07-11-2007, 04:47 AM
TAQuickness's Avatar
How long your parts last depends on how well you build it, and how hard you beat it.
You might consider selling the rods and pistons you have now for a nice off the shelf set that better suite your application.
Old 07-11-2007, 09:40 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Depends on your intercooling setup, and your power goals. While 600rwhp might be attainable on pump gas with decent IAT's, you might end up turning it down to keep it alive, because on the street the engine will be under much more load and will run hotter.
