Boost Leak
Old 09-23-2007, 08:57 PM
AFASTYZFR1's Avatar
Default Boost Leak
Did a boost leak check for the first time today and fixed 4, but air leaks out of the throttle body... NW 90mm.....it leaks from where the throttle blade goes through housing.(circled in pic) is this normal?
Old 09-23-2007, 09:08 PM
phildo's Avatar
Mine does the same. I have a Holley 90mm. I tried replacing it with another and it does the same thing. I would like if this is normal also.
Old 09-23-2007, 09:12 PM
AFASTYZFR1's Avatar
Alot of air goes through it which is a leak and can draw un-metered air.......I could only see like 11psi on the boost gauge even when I cranked the air up.
Old 09-24-2007, 07:30 AM
AFASTYZFR1's Avatar
I think there is a seal....Here is a diy page for a different throttle body
http://ca.dsm.org/FAQ/tb-shaftseals.html
Old 09-26-2007, 07:12 AM
AFASTYZFR1's Avatar
anyone else got suggestions?
Old 09-26-2007, 10:16 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
That's interesting. I will have to check mind since I am running a NW90 and am chasing a big boost leak.
Old 09-26-2007, 12:04 PM
AFASTYZFR1's Avatar
It leaks alot of air and I called Nick and he said I could send it to him, but havn't heard back from him
Quick Reply: Boost Leak
