Help needed... cam and injectors for Turbo Project
I am looking at a turbo cam that specs are 220/216 .564/.561 116+4 LSA
I am also thinking about the speed inc TU1 225/225 .581/.581 113LSA
As far as injectors goes i was thinking about 60lbs motrons but i think with running e85 i am going to need some probably in the 96lb range which is about 72's on gas. I am also new to low impedence injectors and not sure how a converter box works and if it will work with my hp tuners and my stock computer.
Any other suggestions would be greatly appreciated. Thanks in advance for any help and suggestions. Thanks, Tim
I'd seriously consider that 225/113 Speed Inc. cam, not too big, not too small.
I still have my old ported 317's, if you are really interested I can take them to Opel in Streamwood and have him check them. They had a little epoxy work in 1-2 spots where they broke through on the parting, but I had it epoxied by Opel. I'd go pretty cheap on the heads, and the springs are near new.
