8.5 psi D1sc results @ GaFBody Shootout
Old 09-24-2007, 11:06 PM
02NBMFormula's Avatar
Default 8.5 psi D1sc results @ GaFBody Shootout
After getting a good tune from vengence i made a couple good passes last sunday at the georgia fbody shootout. raceweight was 3405lbs, weather was starting to get pretty hot. e/t streets, pulled the front swaybar and flash stalling it
60-1.60
330-4.695
1/8th-7.262@95.03
1000-9.502
1/4-11.398@118.99
with better weather, maybe ill hit 10's but who knows
thanks again bob@ebb and vengence
Old 09-24-2007, 11:30 PM
kp
kp's Avatar
Pretty good on that little boost, when it cools off it will definitely pick up.
Old 09-25-2007, 04:32 AM
EPP
EPP's Avatar
You're welcome! As KP said, when the weather cools down you'll pickup a lot of power. Bob
Old 09-25-2007, 06:42 AM
Rickys S/C Z28's Avatar
good stuff man did you have any over heating issiues?
Old 09-25-2007, 09:39 AM
not at all, but i let it cool down between runs, the $5 i spent to make a manual fan switch has paid itself off three fold. the only time it starts to get hot is cruising at highway speed with the a/c on. im going to work on some ducting to keep things cool. im wondering if i should change the fan setting to always be on. as it sits now, it cuts off at 45mph
Quick Reply: 8.5 psi D1sc results @ GaFBody Shootout
