Procharger D1 will this be OK
Old 09-27-2007, 09:24 PM
somws6bird's Avatar
Default Procharger D1 will this be OK
Ok so I want to add some power to my car but I don't know what route to go. Ive made up my mind on a Procharger D-1SC 8 rib. what I want to know is will my motor be fine with the D-1 and an EPP blower cam, specs are
.050 232int /240exh and .595int .608exh at a 115 LSA. Will change the springs and push rods also. How much boost could it handle and does this sound like a good combo.
Old 09-27-2007, 09:39 PM
nvmy2000ss's Avatar
Sounds like a good combo to me and I think the best decision, of course Im partial. I think you would be safe at 8#'s.
Old 09-27-2007, 09:47 PM
somws6bird's Avatar
8psi then I will keep at that. Im only getting the D-1 because my future plans will demand it and the P-1 will not cut what I have in store for my car. By the way I have almost 100k miles would that really be a problem or doesn't make a difference.
Old 09-28-2007, 04:56 AM
EPP
EPP's Avatar
I put an ATI ProCharger D-1SC on my '99 Z28 when the engine has 110,000 miles on it, without any problems. Check it out here.
http://www.exoticperformanceplus.com...Car.php?car=12 Bob
Old 09-28-2007, 11:47 AM
somws6bird's Avatar
exotic performance plus, I will most likely be coming to you guys for the install of the D-1 and probably the cam and tune also. How much will just the install cost on the
D-1 the EPP cam, pushrods,springs, fuel pump, injectors, if I supply everything, basically just the install, thanks
Old 09-28-2007, 03:46 PM
EPP
EPP's Avatar
Smile
Please send me a pm with your e-mail address, and I'll send you a quote.
Thanks for inquiring. Bob
