2 step
2 step
can i install a 2 step on my turbo ls1 with a 6 speed to make it build boost on the line and if so where is the best place to get one, has anyone done this, i have hears of it just wondering if it will work, thanks
The abilty to retard up to 10 degrees of timing retard has been added to the Linginfelter 2-Step also. It is adjustable from 1* to 10* or the option can be turned off completly. Early versions can be re-flashed for a minimal fee from what I understand. Tested this on thier dyno with my car a few weekends ago. When the retard option is turned ON the Yellow +12V activation controls the 2-step and the Green Ground activation controls the retard function. The retard only becomes active above 3,000 Rpm even if the control signal is ON. The retard can be used while the 2-Step is active if desired.
