Mounting my Procharger and EPP FMIC. Got a problem.
Old 01-12-2008, 05:43 PM
LS1RedZ's Avatar
Default Mounting my Procharger and EPP FMIC. Got a problem.
The box on the driver side frame rail is the cruise control right??.. Correct me if I am wrong? I need to know where to move it so I can run my filter and inlet hose to the procharger..
Old 01-12-2008, 06:26 PM
Funkybird's Avatar
I don't know if its any different but on an LT1 you take the box out of the sheetmetal cover and use the forward mounting hole on the side of the frame rail as the new aft mount and drill two for the front. Hope that helps any.
Old 01-12-2008, 06:34 PM
BlackhawkSS's Avatar
Hey man where you located in Central Texas, I was thinking of installing one of these soon.
As far as the mounting you should be able to drill a couple holes anywhere out of the way and mount it. Theres plenty of options as I just put my cruise back in.
Old 01-12-2008, 06:59 PM
02NBMFormula's Avatar
the ATI kit should come with a relocation bracket. this is what it looks like
and this is how my filter is set up
Old 01-12-2008, 07:01 PM
LS1RedZ's Avatar
I live here in Waco.. We are just about done with everything. Have to go find a hose to run the bypass valve from the bonnet to the intercooler piping. I need to buy a mondo valve or the ATI race valve.. Then I need to cut the bumper put everything back on.. I cant wait till I get this damn thing tuned. Its gonna be a blast...
OKK! I think I figured it out. The kit came with 2 thin pieces of metal with slits in them that look like a slider.. I guess thats what I use to relocate that box..
Old 01-12-2008, 08:36 PM
EPP
EPP's Avatar
Question
Did you not get an instruction manual? Here is a copy if you need it, several pages down is the info on the cruise control. Bob
http://www.exoticperformanceplus.com...html?item=1043
Quick Reply: Mounting my Procharger and EPP FMIC. Got a problem.
