Can you use 317 casting heads on a 3.90 bore LS1 motor?
Old 01-29-2008, 11:27 AM
BadgeZ28's Avatar
Default Can you use 317 casting heads on a 3.90 bore LS1 motor?
I read in another thread that you can't run them because the valves are spread further apart (???). I was under the impression they just had a bigger combustion chamber and valve spacing and clearance was the same as LS1 heads. Thanks
Old 01-29-2008, 11:35 AM
30th t/a's Avatar
yes you can
Old 01-29-2008, 11:40 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Tons of people do it. Whoever said they wouldn't fit is wrong.
Old 01-29-2008, 12:09 PM
y2khawk's Avatar
Just need to use the correct size gaskets for the heads.
Old 01-29-2008, 12:29 PM
smokinHawk's Avatar
yes use the 4.0 gasket for a 4" bore head
i am using the 317 heads on my 3.905" bore ls1
you cannot use the l92 heads on a 3.9" engine, you have to use them on a 4.0" bore or larger. (you might be thinking those heads that you cant use)
Old 01-29-2008, 01:26 PM
BadgeZ28's Avatar
My mistake. He did say L92 heads. But I am glad I asked because of the gasket requirement. Thanks
Old 01-29-2008, 03:44 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Nope. L92 heads require at least a 4.00" bore cylinder.
Keith
Quick Reply: Can you use 317 casting heads on a 3.90 bore LS1 motor?
