what oil do you recomend for a 383 stroker, sts rear mount?
im either gonna get 5w30 mobil 1 or the german castrol 0w30. what wuold you recomend? is ther anything i should know about oil with a turbo?
what do you think about rotella t in my rear mount? would that be to thick to travel back there?
can somone explain to me what thickness of oil i should pick? why i should pick different ones for the climate? i live in jersey. the car only comes out when its nice, otherwise it stays garaged.
We all have our personal favorites, but the truth is if you use modern multi weight oils designed for gasoline motors, the only way to really go wrong is Quaker State. You would be hard pressed to find anyone here (the FI forum) who has had an oil related engine failure. Most have some sort of "ran the motor too damn hard" failure long before the oil is an issue.
im leaning towards the rotella t. what do you recomend? regular 15w40 or synthetic 5w40? the new motor has about 10k miles on it. im just more worried about the oil getting to the turbo fast anough
my motor has 10k miles on it. so im looking for a good synthetic with my sts setup. is rotella t synthetic good? if not what would you recomend? what weight oil should i stay around. for summer weather in nj.
I have a 408 and a STS and I run the Rotella oil.My friend is a deisel machanic for Schnucks grocery stores here in St.Louis and thats what they run In all there trucks,and they dont change the oil In those trucks very often.He also runs it in all his vehicles.
