408 and F1A procharger
Wat kind of power should i expect. The 408 is 9 to 1 dart 225s custom grind cam all the good stuff. Just wondering kind of power to expect the car made 456rwhp on motor.
Gauging from past results, about 14psi or so is right around the 800 level with AFR heads and 6spd trans. Depending on how big the cam is , and how well the combo works, it should be anywhere from 700-900 depending on pulley.
I'm at 730rwhp@5000 rpm and 10 psi-I'm expecting around 950+@6700-7000. This is through a auto and pump gas. The 730 was just dialing it in yet-still have to throw lots of timing at it! Hopefully I'll get the belt slip issues sorted out this weekend.
This list may help you out some.
http://www.exoticperformanceplus.com....html?item=540 Bob
hahahahahaha!!! been there done that, dont go to the track without a diff in the thing, last year I got 2 passes in then I sheared the bolts off the ring gear on mine and my buddy who has a mild bolt on TA broke his. we had tandom flatbeads trailor us 100 miles back to my shop. GOOD TIMES
Is the kit pretty simple to install? Just wondering i would like to try and do it myself and wondering how hard it is? The kit has front mount and and the 9 inch spal fan. Wat parts will i have to remove?
