Getting alot of pressure in radiator when boosted.Help?
I took my car to the track and evertime we run we noticed antifreeze up under the hood and it seems to be getting worse. When you rev up the engine a little it is fine until you rev it up enough to push boost and then it shoots antifreeze out of the catch can overflow and the radiator cap. If you remember a while back I had a post on my car losing boost 20psi on the dyno one time and 15psi the next. Could it be a blown gasket causing the boost to blow pressure back into the water.
I bought the car already built and the heads have Avenger CNC ported on the front side of them. I really dont know alot about them. Hopefully I will find out everything now that I have to take it down.
