anyone have pics of their installed meth kit
im looking at my car right now and i have no idea where the hell im going to install the meth pump and the tank for it anyone have anyideas or pics that would really help thanks
I ran into the same problem as you Witry, I'm going to be running the Snow Performance Kit that comes with the variable controller. I was thinking about using my windshield fluid tank (which is what a lot of people recommend) but instead decided that I'm going to instead have the tank mounted in the spare tire well instead (because I actually use my windshield washer fluid). It hasn't been installed yet nor am I sure about the placement of the meth pump but I will be running the 2.5 gallon resevior that they just came out with.
8 sec potential, 12 sec slip
Here is how I have mine currently:
Here is how I had it before my FMIC:
https://ls1tech.com/forums/showthrea...821&highlight=
There are more threads about meth mounting locations in here, try a search :
https://ls1tech.com/forums/showthrea...006&highlight=
http://www.alcoholinjectionsystems.com/
check out the trunk set up.. expensive but seems there the best. and u can get the progressive control kit
Consider moving your battery to the trunk and installing your methanol reservoir in its place up front. Mine mounts the AlkyControl pump right under the methanol tank in that "battery" position, which also minimizes the line lengths.
the only issue i have being trunk mounted is maybe the delay of the meth getting to the motor when the boost hits..... trans2000am doing good im just visually installing it now so i get an idea where everything goes so i dont take me a week to do this kit lol
