stock ls1 springs?
Old 06-03-2008, 01:09 PM
allthrotle's Avatar
Default stock ls1 springs?
I plan on running 7-8lbs with a d1sc on a stock bone stock ls1, should or do I have to change the valve springs or will the stock springs be able to hold the extra blower pressure?
Old 06-03-2008, 01:17 PM
LS1Tech Sponsor
hellbents10's Avatar
Change them, they are not good with only about 70-80#'s on the seat lol.
Old 06-03-2008, 01:21 PM
allthrotle's Avatar
Dammit. I was hoping to get away with using them.
Old 06-03-2008, 02:46 PM
LS1Tech Sponsor
Sorry, I would recommend PSI or Patriot duals.
Old 06-03-2008, 04:31 PM
Reject's Avatar
dont skimp out on springs get duals heard... and seen what happens when a single breaks... not pretty
Old 06-03-2008, 06:27 PM
Hugger Z's Avatar
If you are tight on cash and only running 7-8psi, the LS6 valvesprings are affordable and working great on my car with the same boost. If you want to go higher than that, you will need better springs. But these work fine with low boost.
Old 06-03-2008, 06:34 PM
allthrotle's Avatar
Cool I'll definetly consider that, thanks.
Old 06-03-2008, 09:11 PM
9t8z28's Avatar
Comp 918's here with 7 p.s.i. and no problems, just a little noisy!
Quick Reply: stock ls1 springs?
