my car falls on its face in 4th gear..Help
Old 07-03-2008, 04:47 PM
Boosted 99 TA's Avatar
Default my car falls on its face in 4th gear..Help
Hey guys i just recently put a sts kit on my car and im having some troubles. I got the tune done a couple months ago but it was only runnin 3psi during the tune, i had to bring it home and figure out why it was only runnin 3 psi and i figured it out and now am runing 6psi. well today i drove it for like the second time with this much boost and got on the high way and ripped it 1st-4th gear (m6) well 1-3rd gears all went good but when i got into 4th and got up to about 4500 rpm my car just fell on its face and that was it. Do you think it could be because i only got it tuned with 3lbs. My tuner said he tried to make it as best as he could for when i up my boost and told me to bring it back. I never got on it hard when i was only runnin 3psi so thats why i dont know if its a tuning issue rather than something mechanical. i had W2W do a SD tune on it. And they did what they could for the time being. Tell me whta you think
Old 07-03-2008, 05:25 PM
LS1Tech Sponsor
hellbents10's Avatar
Could be a number of things. You need to have a wideband and logging capabilities.
Old 07-03-2008, 07:26 PM
OUTLAWZ RACING's Avatar
Simple get it tuned!
Old 07-03-2008, 08:01 PM
01FbTaWs6's Avatar
im betting it is a lean stumble. I would be getting that tuned.
Old 07-03-2008, 08:29 PM
Sideways240sx's Avatar
yea.. I dont even want to go from 6-8 without getting it back on dyno, and tuned again.
You definatly want to get a wideband on the car if your going to drive it at all, make sure your afr is good, and get it back to a tuner.
As stated could be a bunch of things though. Chris
Old 07-03-2008, 10:49 PM
ModularTurbo's Avatar
don't get on it anymore either. if it is lean you don't wanna hurt the motor.
Old 07-03-2008, 11:23 PM
theblur98ss's Avatar
Definately get it tuned. I've seen some engines damaged from this exact thing. The boost was higher but definatly don't beat on it any more.
Old 07-04-2008, 02:29 AM
thanks guys i emailed the tuner right after it did that so ill get it back on the dyno and get it tuned again.
Quick Reply: my car falls on its face in 4th gear..Help
