Are exhaust cutouts worth it on a turbo car?
Old 07-11-2008, 11:05 AM
nastysupaspt's Avatar
Default Are exhaust cutouts worth it on a turbo car?
Any guys running exhaust cutouts? if so how much power did you gain from them? Also are the QTP cut outs worth $400 i thought that was a little pricey.
i was just thinking on going with Flowtech cut outs.
Old 07-11-2008, 11:26 AM
30th t/a's Avatar
i got them for the sound alone. my car sounds like jet going down the street, and i like that. i just bought regular cutouts for now. $45 for the pair. depending on the rest of your exhaust, that will determine how much the cutouts will help with power.
Old 07-11-2008, 11:36 AM
smokinHawk's Avatar
YES THEY WILL VERY MUCH SO
i never got mine dyno with and without, but my butt dyno said it added a good 50rwhp
its cheap horespower
i dont think i would spend $400 for one though, maybe <200 for an electric one.
Old 07-11-2008, 11:44 AM
Firechikn's Avatar
Running through the 3" catback, my car will only make 12-13 lbs. With the 2 3" cutouts open ( 4" dp ) its all good. I've got QTP's on mine and they haven't quit yet. Just a flip of a swith and they're open.
Old 07-11-2008, 12:03 PM
cablebandit's Avatar
i have a manual one i open at the track. i do know that when its opened, i have to add fuel to my ve table so i know its making more power.
Old 07-11-2008, 12:55 PM
LS1TECH Sponsor
DrTurbo's Avatar
Yes....you will gain power and spool up is a little better as well.
Old 07-11-2008, 07:02 PM
engineermike's Avatar
BE CAREFUL!!!
Depending on how good your exhaust is, you may wind up with a blown motor. I did this one time and it gained 10+ psi boost due to removing backpressure from the turbine.
That said, I hate cutouts. I hate complication, more moving parts, and most of all, I hate having to flip a switch to get MY power. If you think you need a cutout, then you really just need a better/bigger exhaust system. With my 3.5" exhaust with a Magnaflow muffler, I gain little to nothing by removing it.
Mike
Old 07-12-2008, 10:27 AM
well my car now has the 3" hooker y pipe which is bolted right up to the aps down pipes and from there back no cats and a corsa 3" exhaust. If i do the cutouts i was thinking of welding them right at the end of the Aps downpipes off the turbos i think the car will gain some pretty good power. One thing i don't want it to do though is boost creep
Old 07-12-2008, 10:47 AM
kbracing96's Avatar
I picked up a 1/2 second doing nothing but opening the cutout on my old Warlock muffler on my truck when I ran 11psi at the track.
Old 07-12-2008, 10:51 AM
damn thats awesome!!!!!!!!!!! 1/2 sec is alot
Old 07-12-2008, 10:53 AM
Keep in mind that turbo cars almost always gain boost when you open the cutout. So, when someone says they gained a 1/2 second, a fair amount of it probably came from a rise in boost.
Mike
Old 07-12-2008, 10:59 AM
Stupid Boost's Avatar
Default ....
Originally Posted by engineermike
BE CAREFUL!!!
Mike
I agree with Mike,If it helps you've got to small an exhaust.But sometimes if you want a really quiet car,it's the only choice.
Old 07-12-2008, 11:38 AM
MY99TAWS6's Avatar
I have had a QTP and DMH and now have STREET PRO. The qtp rattled when closed and broke after I sold it . The dmh worked good but rattled when closed. The street pro is very pricey but doesn't rattle when closed and has been working perfectly. I am very happy with it and likely buy another one for my 96z28.
DMH and QTP might have redesigned their products I had them quite a few years back. DMH offered to fix mine but sold it rather than going thru hassle of shipping it back, a bit of pain since I am up in Canada.
Cutout is high on my list of favorite mod.You can have your car nice and quiet when they are closed,open them up a little bit or a lot and get the sound where you like it. I like to put the fear of god into hondas sometimes at the lights.Its great fun!
For some reason in a few of my NA tests the car seems slower with the cutout not sure why. It should really help though on a turbo car epecially one like mine that has 3 inch single exhaust. For now going to be running single cutout only in intermediate pipe.
Old 07-12-2008, 12:32 PM
how much more are the street pro's compared to the qtp ?
sounds like to me there worth the money
Old 07-12-2008, 12:51 PM
WS6HUMMER's Avatar
How can a car pick up more boost with a wastegate and boost control valve in the equation? I thought they would limit the amount of boos the car will make.
Old 07-12-2008, 01:23 PM
W8N2SQZ's Avatar
It all comes down to flow. Even with the gate, the less restriction and better flow of the exhaust will affect spool characteristics. THe gate is just a valve that flows air past it. Change the exhaust back pressure after the gate and there will be a difference.
Old 07-12-2008, 02:17 PM
Frost's Avatar
Electric cutout on STS ftl!!
the ultimate boost limiter
Old 07-12-2008, 03:19 PM
MY99TAWS6's Avatar
They are like 250 each .I just have one. I think they are worth the money. The rattling of the qtp and the dmh got on my nerves.I am picky though.
Old 07-12-2008, 03:20 PM
Boost control valves are Proportional controllers only, not Feedback. Change any one part of the system and the boost pressure will change too.
Mike
Old 07-12-2008, 05:59 PM
o2ws8's Avatar
I have dual cutouts and when i open them the car feels totally different it pulls way harder!So in my opinion I say they do make a difference!!
Quick Reply: Are exhaust cutouts worth it on a turbo car?
