Injector Flow Rate with 8psi and 60lb/hr......
I just got my Paxton Blower installed and fired it up for the first time, it has no idle and when you rev it up clouds of black smoke comming out of the exhaust, so I assume its getting way too much of gas.
I have Siemens 60lbs/hr injectors and my flow rate table starts at 7.66 and goes up to 8.39
any suggestions what a good flow rate table should look like with these injectors and 8psi of boost?
your's is really looking completely different, which tuning software you're using?
I have LS1edit and it measures flow in Gm/sec, If I see it correctly your program measures flow in lb/hr
do you have an Idea how to convert your table into Gm/sec?
ok thanks for converting it!
the numbers on your chart still look different compared to mine
while your numbers are increasing, mine are decreasing
at 80kpa yours is showing 7.45 mine says 7.85
at 20kpa yours is 6.98 mine 8.39
very strange
very strange
