Got my turbo, now what size wastegate?
Bought a new 88mm turbo with .96 ar on the hotside with a t-6 flange from another member but it came from dave at majestic. It has the hotside already jet coated and comes with a sleeve to neck it down to a 76mm which im sure I wont use.
Its going on a 408 iron block. going to be right around 8.8cr. Will probably start around 8-10psi and dont plan to run over 18psi. Will a single 50mm jgs wastegate work?
