Intercooler/cold side pipe size
Setup: 5.3 stock, Master Power t70 .68ar, will be street driven, pump gas
Turbo compressor outlet is 2.5"
Can I run 2.5" pipe to a 2.5" inlet/outlet intercooler, than transition up to throttle body size after the intercooler?
Or should I run a larger intercooler inlet/outlet and larger pipe alltogether?
Any help would be great
Thanks,
Matt
Thanks,
Matt
Run what's on the intercooler, going bigger isn't going to make ANY difference unless you're going to bend (pinch) the hell out of the pipe on it's way. I had the same turbo, and sounds like the same style intercooler, 2.5 the entire way and then used a coupler to go to the MAF/TB.
If you already have the intercooler at 2.5" then I'd just run everything that size. If you don't have it yet I'd get a 3" and come off the turbo with a 2.5 to 3 increaser and run the cold side in 3" just in case you decide to go bigger in the future.
