Best methanol injection system??
Not trying to start a fight or anything, im simply looking for the most advanced meth system available.
Something that can be triggered by both RPM AND throttleposition for example.
Something with a big enough tank not to run out in 3 races
etc...
PS.
questions on what to run in the meth tank. Is obvious some would argue 50 meth, 50 water. But what if i tell you my friend has been running mineral bottled water in his vette for the past year, and he drives it daily. A friend of mine told me that a small meth tank costs $400 here in Dubai and it will most likely run out in 5 races.
My purpose is to increase my octane rating and make use of cooling the IAT's.
Suggestions would be appreciated, im also searching while I get some answers.
etc...
PS.
Alkycontrol I believe is one of the best systems
I would run pure meth more cooling power/ higher rise in octane/can make more power on it.
With a good kit you can run any tanks size you want.
I dont live there so i have no idea how much meth cost per gal there. But cant see it being 400 a small tank. Its about 5 dollars a gal here
If its really hot there i can see running a mixes of 50/50 to keep the meth from boiling in the tank. but pure water is not the best way to go.
Its can last for months or days no way to know till you tune it and how much you need to keep temps and knocking down.
WHY do you want it trigger by rpm or tps ?
